It is currently Wed Aug 20, 2025 5:14 pm
PostPosted: Sat Jan 18, 2014 6:44 am
Hi all,
I posted this question on the repair board, but only got one reply; maybe more people will see it here.
A first time operation for me: regluing celluloid bindings that have pulled away from the waist. The guitar is a 1970's Vega dread. It needs a neck reset, too, so I've got the neck off. I'll separate the bindings from the waist all the way up to the neck, then reglue them. My question is what glue to use. My first thought was to go with one of the glues commonly used for plastic bindings: weld-on or one of the glues LMI sells for this purpose. But the more I think about cleaning that stuff up after gluing, the more I think maybe there are better options for a repair situation like this.
On this page, Frank Ford demonstrates using wood glue for this: http://frets.com/FretsPages/Luthier/Tec ... nding.html
Now, Frank is a trusted source, but I can't help worrying a bit about wood glue having sufficient bonding strength with a plastic like celluloid. Can anyone here confirm that wood glue is a good choice? Or, for that matter, hide glue or fish glue? My understanding is that animal glues have been used to bond various materials like glass, for example, though I don't personally have experience with this, and I'm not sure about plastics. It sure would be nice to be able to clean up with water and leave the finish unscathed.
I would even consider epoxy, as I could clean that up with alcohol before it cures, but a water clean up would be ideal.
Thanks!
Todd Rose
Ithaca, NY
PostPosted: Sat Jan 18, 2014 8:55 am
I use Titebond. So far it seems to work great. Perhaps someone with more experience will speak up.
PostPosted: Sat Jan 18, 2014 3:46 pm
Thanks for your input, Steve!
Todd Rose
Ithaca, NY
PostPosted: Sat Jan 18, 2014 6:20 pm
If there are fine wood fibres on the surface of the celluloid, titebond will adhere fine.
PostPosted: Sun Jan 19, 2014 8:14 am
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Roo Glue ........ RooClear for specifics... dries complete clear and will glue almost anything..... It was designed for Melamine and Vinyl but haven't found much it want glue. Been using all Roo Glue products for several years now ( 4 different glues ) ....... no comparison to the major 3 other companies in our opinion.
Blessings,
Kevin
These users thanked the author Kevin Waldron for the post: klooker (Sun Jan 19, 2014 9:45 am)
PostPosted: Sun Jan 19, 2014 9:27 am
That makes sense, Jeff.
Steve, in your experience, have you found that having wood fibers on the surface of the celluloid is requisite to bonding with Titebond?
Todd Rose
Ithaca, NY
PostPosted: Sun Jan 19, 2014 9:39 am
Blessings,
Kevin
Hadn't heard of Roo Glue before, Kevin. Just looked at their web site. Sounds good. However, they describe their glues as being highly water resistant and difficult to clean up once cured. For this application (regluing bindings on a finished instrument), it seems to me that being able to clean up with water after removing the tape would be a major time savings over using any kind of glue that will require scraping to clean up.
Todd Rose
Ithaca, NY
PostPosted: Sun Jan 19, 2014 4:46 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Todd,
Wouldn't have recommended it if I thought it wouldn't work for your applications... suggest you get some and try on something as an experiment.
Blessings,
Kevin
PostPosted: Sun Jan 19, 2014 7:57 pm
Thanks, Kevin. I'll consider it.
Todd Rose
Ithaca, NY
PostPosted: Sun Jan 19, 2014 8:42 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
If it were me, I would use Titebond (orig.). It won't harm your finish and any glue residue after it dries can be cleaned up with water.
PostPosted: Tue Jan 21, 2014 5:17 pm
Thanks for your input, Wayne. If you've had good luck with regluing celluloid bindings with Titebond, in cases where there are no wood fibers stuck to the surface of the celluloid, I'd be interested in hearing about that.
In the case of the Vega I'm working on, the bindings came off with some glue stuck to them, but no wood. It's a yellowish, gummy glue that remains mostly on the wood of the binding channels, and a little on the bindings, and it is proving to be a pain to get it off -- not so bad getting it off the bindings, but tough to get it off the wood.
In any case, with the bindings cleaned up, I'm don't think I'm going to try Titebond. I posted my question on another forum, too, and got a very helpful reply, which I will quote here:
"I've used LMI's FCA contact adhesive for two repairs, now, and it's the cat's meow. Paint it on with a small brush, press the binding on, no problem. No squeeze out and the brush allows great control of the glue application to keep from contaminating the neighboring finish. Clamping helps to get full contact -- because of the lack of squeeze-out, it's very easy to firmly tape the re-attached binding to the body without danger of smearing. The brush cleans up completely with acetone, so no problem there, either. I use an artist's brush appropriate to the size of the job.
I've tried the wood glue method but unless there's some wood chunks stuck to the binding and there is an exact fit with the separated wood area, it hasn't worked for me."
This sounds good to me. I've ordered some of the FCA adhesive from LMI.
Todd Rose
Ithaca, NY
PostPosted: Tue Jan 21, 2014 9:46 pm
Last Name: Killin
Todd,
This is a timely post. I'm about to start working on a late 70's Martin that the binding is coming loose. I'd love to hear your feedback on the LMI glue. I had planned on using Duco for this one but if there is something better, I'd like to know.
PostPosted: Sat Feb 01, 2014 6:34 am
Update:
I used a chisel and palette knife - both heated with a propane torch - to remove the old glue from the binding channels. Worked well and went pretty fast. Scraped the old glue from the bindings with an exacto knife.
The LMI FCA adhesive worked well. Provides less than a minute of open time, so I worked quickly, one section at a time, taping the binding down as I went. I brushed it on with a small, cheap artists brush - a flat brush about 3/16" wide. The beauty of this adhesive is that, although it is a fairly thin liquid in the bottle, it begins to set up into a gummy substance the instant you brush it on, and then, unless you've applied way too much (which I did in a couple spots), it doesn't squeeze out, so it's possible to do a very clean job.
As an experiment, on one side I did a short section using StewMac brush on CA. That provides plenty of open time, and adheres well. A viable alternative, I'd say, but I found it more difficult to control in terms of squeeze out. I did the rest of that side with the LMI stuff.
Todd Rose
Ithaca, NY
PostPosted: Sat Feb 01, 2014 11:34 am
First name: george
Last Name: s
Re: " I've tried the wood glue method but unless there's some wood chunks stuck to the binding and there is an exact fit with the separated wood area, it hasn't worked for me."
If there are no wood fibers to bind, I have found scuffing the surface of the binding that will be glued
and then using Titebond works well. then tape it with low tack tape (painter's tape that I stick on my pant leg before using).
Regards, G
PostPosted: Mon Feb 03, 2014 6:40 am
Regards, G
Interesting. Thanks.
Todd Rose
Ithaca, NY
PostPosted: Mon Feb 03, 2014 6:42 am
In the other thread (on the repair board) I started on this same topic, Todd Stock made a post with lots of pertinent observations from his experience.
viewtopic.php?f=10137&t=42475&p=562490#p562490
Todd Rose
Ithaca, NY
